Tiff
- Joined
- Dec 15, 2008
- Messages
- 76
It could probably be made to work, but the first big hurdle is that the Mag LED unit is bigger in diameter than a standard PR bulb, so it won't fit in the unmodified socket of most other lights. Some folks have bored the socket out to accept it, you would have to determine if your light can handle that. The thermal management circuit in the Mag unit SHOULD prevent melting the plastic socket, so once it's in, it will probably work OK.
Yep, that's what I did! I modified the opening which was aluminum and got it so it fit. I used tinfoil as a cheap heatsink and wedged it in to keep it in place but the overall gain was not enough to spend the $15 for it so it goes back and I'll run a Nite-Ize in one and a Dorcy in another and find something for my 6 volt. The Dorcy sounds good 45 lumens and the Nite-Ize should give long runtimes. Plus they are cheap enough that I won't feel ripped off if they don't work out too well. I want one as a flood and lower power and maybe a brighter one to provide some extra throw. Since I already own these lights and like using them.
Heat might be an issue with 3 watts as the front is plastic and not glass.
Be nice if there was a melting smilie.
