fyrstormer
Banned
Thank you Doug, your application of the Law of Conservation of Energy is what I was trying to explain before.
They claim there's no magnets in the wheel or rim and it doesn't touch the rim. As I see it, they could put coils and magnets in the device, and it wouldn't have any internal moving parts. But any eddy currents would be generated in the rim and therefore unavailable to power the light, and I see no way to make this work.
At the risk of going off-topic, I don't think this is as much of a problem as the literature you read may have implied. Certainly voltage spikes can happen, but lead-acid batteries can absorb charge about as fast as they can dump it, and they exert considerable "electrical inertia" (my own made-up term) against changes in overall system voltage. With 18-wheeler batteries that can output (or input) >1000amps for a short time, it would take a seriously beastly generator to output enough wattage to keep a voltage spike from drooping back to safe levels. Also, the wiring in the vehicle itself would apply strong resistance to the surge of amperage following a voltage spike, which would be a serious problem if it lasted long enough to generate substantial heat, but for a split-second spike the wires would just act as resistors to keep things under control.By chance, I spent some time last week looking at a paper describing ways to improve the regulation in an automobile alternator. It was a good review... they do indeed use battery power to get the field current flowing initially. The field current is adjusted in order to control the output voltage. Problems show up when the load on the battery changes suddenly, and the control circuit takes time to respond. The resulting voltage overshoot can be on the order of 150v for large diesel engines with 24v batteries. It'll be less for 12v autos, but it does show that any LED lights you build for your car need suitable protection circuitry.
I agree with your train of thought, and ran into the same wall myself. It did occur to me, though, that another method was possible. Eddy currents are still used, but the drag produced by the eddy currents can be used to spin a magnetized wheel inside the dynamo gadget. The magnetized wheel, once spinning, can generate changing magnetic flux which can be directed through a coil to produce AC current. (I really need to do a sketch of this idea...)
Soooo - could someone remind an old bloke again please.... exactly what was it that's wrong with my hub dynamo (sitting down there safe and unbreakable within the wheel, unable to fall off or get bent, connectable to all sorts of home made lighting contraptions and working with negligible 'drag')?
Savvas.
The trouble here seems to be the assertion of no moving parts. ...
is it possible it's partially active, analogous to the field windings in a field controlled dc motor? My physics stinks
They've mentioned magnets inside the device. They've also mentioned that it doesn't touch the wheel, and there's no magnets mounted in the wheel -- it's all in that one device that's mounted to the brake.They have not claimed no moving parts, but that device doesn't really have much room for moving parts -- and I don't see how moving parts would help. But certainly, moving parts are not off the table. (Though anything that could be done with moving parts could probably be done without them.)But here's the thing -- generators work by moving a coil and a magnet relative to each other. If both coil and magnet are inside this device (as they must be), they have no relative motion and generate no electricity. You could move the coil and magnet relative to each other in the device, but that would require energy that isn't available unless there's another generator of some sort ...More fundamentally, generators work by putting a coil in a changing magnetic field (and usually the changing magnetic field is generated by moving the magnet and coil relative to each other, but there are other ways). The magnet in the device would create eddy currents in the rim, but with no way to collect them, they'd be wasted to heat.And these eddy currents would also create a magnetic field -- but at the bike light, this field would be static and therefore not useful in generating electricity.As I see it, they've either put magnets in the rim (which they say they have not) ... or it's a complete scam, powered by a battery. (And their video of the wheel being spun by hand suggests the latter, as the wheel didn't slow at all -- and it should have.) Now, perhaps it's not *intended* to be a scam, as they think having the money will allow them to work through the physics have have eluded them so far. Or maybe they know it won't work. Or maybe they really have discovered something fundamentally new that nobody else has discovered in the last two hundred years, something fundamentally new in a field where nothing really "new" has been discovered in quite some time.We shall see.They say it'll be demonstrated at a show this weekend, so maybe somebody not associated with them will get to look carefully at their demonstration models. (Though even if I do see a post from somebody saying it all seems legit, I'm not going to believe it unless it comes with a fairly detailed and plausable explanation of exactly how it works. After all, such a post could come from these people too.)I don't buy their worries about their patents not being issued yet -- what matters is when the request was filed, not when the patent was issued. If they really needed to protect it until then, they need to keep it a secret -- as anbody with some skill this field ought to be able to figure out how it works just seeing the demonstration of it working.longer answer: yes, but... it seems unnecessary (to me), and it adds cost and complexity. We know that the design uses rare earth magnets, so that pretty much takes care of the method of generating a magnetic field. Maybe it could be used to modulate the magnetic field for some purpose?? Perhaps.. but I'm unable to think of how/why to do this.
No, somebody is right and somebody is wrong. We just don't know who yet. (This isn't Schroedinger's cat ...)Until someone reverse engineers the light, or the designers show us the internal bits, we get to have fun speculating about how it works and no one is right or wrong. .
Without a changing magnetic field through a coil, you will not get a current out of the coil. With this the Eddy currents need to vary with time. For that you need to initiate them through some primary coil where the current varies with time. But that coil will be inducing Eddy currents not just in the rim but everywhere else. Much of that energy will be just dissipated away. Energy of the magnetic field due to the current in the rim spreads out to all sides. A coil half a centimeter away, on one side, would be collecting just a portion of that energy. No wonder you always try to surround all space, when a field in similar situations is produced, and leave as small gaps as possible.
That could work -- if there was a strong magnet on the rim. As this magnet spun past your disk, it would cause your disk to move. (You could also skip the middle man and just replace your disk with a coil to pick up energy directly from the changing magnetic field.)edit: okay..... I've got working theory on how it works. It involves a magnetized disc that gets spun by the eddy currents dragging it around.
