I have chargers which run at 0.25C or less, and which seem to terminate pretty reliably - cells seem to have essentially as much in them as when charged at faster rates, and are not unduly warmed at the end of charge.
That is indeed the problem. With such low rates, the cells don't really get hot (so to notice something is wrong) and if there is a missed termination they are cooked to death. You'll never know unless if you time the charge and know in advance how much charge is already in the battery. So, the charge and the charger might look perfectly normal but at the same time it may cook the battery to death and still give the impression everything is just fine and terminates properly and reliably. Batteries can give a good -dV signal even at such low rates, however this is not true under all circumstances during their full extend of useful life (depends on the quality/condition of the battery). Brand new or well used batteries are the most prone to fail at some point in their life in producing the necessary -dV with low charge rates. Very stubborn batteries may fail to produce that -dV even with higher charge rates but the chance of this happening is drastically reduced.
