TorchBoy
How much heat will there be? 0.33C for a 1000mAh cell is 330mA. At 1.5V is 0.5W. Next question, how much of that 0.5W will convectional, conductive, and radiative cooling remove? The cells are warm, yes? But not hot because they are being cooled as they go. MHO is that they are being charged, and maybe damaged in the process.SilverFox said:I agree with NiOOH. This is very strange behavior. Continual charging should heat the cells up.
SilverFox said:I suppose there is a certain irony in us having the best flashlights and the crappiest cells...
The two AAA cells that I managed to put through the break in finally finished so I discharged them at 400mA and got 615 and 619 - the same as in the break in 0.2C discharge. But now I can't recharge them because they both read HIGH (again). Yes, I can dig out another charger to give them a bit of cycling (discharging on the C9000 to get capacity readings) but like jusko said, this charger is supposed to be good at this sort of thing.
Forgive me if it's a stupid question but why is it checking impedance on break in mode? This is the mode we'll be using if we want to rejuvenate stubborn cells. I should be able to use it for this, even if the cells are too poked to charge normally.
I've even contemplating putting a resistor across the battery terminals during the impedance test.
