HDS lost me at about $250 cheapest light they make...
For that money it should come with a FREE 18650 tube.
In addition I am not going to waste my money on arrogant HDS dealers.
When something is that expensive the dealers that represent HDS should be carefully chosen.
And no, I am not buying the HDS maker has no control over the HDS dealers.
I am not exactly sure how to respond to this, but i will say this... after I say, how did this become a Malkoff/HDS systems thread...hahaha
ok... A malkoff device is a straight forward device and will cost around _$100ish- $150ish MDC/MD2 M61. Straight forward and simple. Great design, durable, fairly good finish quality. A programmable Malkoff will most likely be more expensive if it ever comes to reality. 1-3 modes of output, currently
HDS systems is an entirely different class. Malkoff is like a Spyderco, HDS is like a Chris Reeves. There is a lot involved in a HDS and battery tubes are not just tubes like Malkoff. there are electronics in both the head and tail on an HDS.
Sure HDS is a bit more expensive but look at what you are getting for the price difference. Look at the whole picture and you will see that the price is not all that bad.
Possibly a more rugged light (subjective)
Higher tolerances in design/build quality
Better quality in fit/finish
user programmable with several additional features
24 modes of output easily accessible
Can be programmed to work as a Rotary and clicky
Light is actually calibrated and more efficient
I'm sure there is more to say but i will leave it here. A HDS Rotary can replace all Malkoff lights 350+ lm range into 1 single light (will keep up with an M61/MDC16650. I have many Malkoff lights which cost several hundreds to thousands of dollars; where i only need 1 HDS rotary to replace most of the Malkoffs i own. So HDS is not over priced and as good if not better than lights of higher output.
Most people do not look at all the details and complete picture and only focus on price. yes $250+ seems like a lot for 1 light, but you are getting many lights in one that is stupid simple to use, just as the Malkoffs. Malkoff and HDS are my 2 favorite brands and i will continue to support both.
Not sure where you are having issues with HDS dealers, I buy direct From Henry as i do from Gene, or i buy in the marketplace here and that is it for me. Both companies also have a great support system here which is a plus for me, but i will give credit to Malkoff for having the best customer service hands down.
Hmmm...As a Malkoff junkie and a prospective HDS customer, that's something to consider. No matter what happens, whether Malkoff creates this new thing or not, my high/low rings and my drop ins won't be going anywhere.
I on the other hand have had more issues with Malkoff and none so far with HDS systems. I have told you this before, but You need to at least try one out, even if you buy from the marketplace (which is where i recommend to start)
I am always in for checking out new products from Gene, we will see what he brings this year
