Thanks for the suggestions. I see there are Mule Hi CRI's available but they appear to be just as much as the Sundrop XR-U that is available. I would spend a couple hundred for a light but not sure about $400. If there isn't a good McGizmo flood light option for under 300 I may just go with the Zebralight. I gotta say the McGizmo's are pretty nice looking though.
A McGizmo will last longer than you will, and they're now available with 1/4" tripod mount-compatible pocket clips.
The Mule Hi-CRI is the best light for photography work. I have a Mule Hi-CRI plus one of every other (not ultra-rare) light that McGizmo has made, and the Mule is the one I always use for photography. If you make money with your photography, getting a Mule is a no-brainer; you
will use it on a regular basis, and it doesn't cost nearly as much as a pro-grade DSLR camera.
An alternate option is to get a Haiku Hi-CRI instead, and put a SureFire-brand 1" white diffuser on it when you need flood lighting. That would help defray the cost a bit, since you could use the Haiku for walking at night, peering into dark corners, etc. The Haiku will be somewhat more focused than the Mule even with the Diffuser installed, more like a SunDrop without the bright ring around the edge of the beam. Just something to consider.
One last thought: last I checked, the the Zebralight Hi-CRI lights don't have as high a color-rendering index (which is rather important for capturing the exact appearance of food, otherwise it comes out looking...wrong, somehow), and their tint is much warmer too. McGizmo Hi-CRI emitters are pretty much the best you can get in a pre-built flashlight.
