45/70
I'm also curious to know how often everybody does a "refresh" R&A cycle on their LSD and non-LSD batteries? Never? Every X months? Every X times used?
I've been using individual rechargeable cylindrical nickel based cells (ie. not "packs") since the early 80's and NiMH cells in particular since they first came to the consumer market. Here is how I maintain the different chemistries.
NiCd. I run either a complete use cycle (ie. down to an OC voltage of ~1.20 Volt) every time I use them, if possible. Every one to two months when they are being used, I run a "break-in" cycle. For storage, I discharge them to 1.20 Volts, or less, and store them at room temp. I do not attempt to "top up" NiCd cells when in storage. This only promotes crystalline growth and the associated voltage depression due to self discharge during storage. When removing from storage, I revitalize the cells with a "break-in" cycle.
Traditional NiMH. I run these through a complete use cycle every month, or so (preferably not each cycle) and do a "break-in" every 3-6 months. If the cells are not frequently used, 3 months, and if they are in pretty much continuous use 6 months. For storage I store them with a small amount of charge, eg. 1.25 Volts or so OC, at room temperature. When checking stored cells, if the voltage drops below ~1.20 Volts, I charge them up to 1.30 Volts, or so and put them back in storage (The voltage usually drops to ~1.25 Volts after a short time). When removing from storage, I run a "break-in" cycle.
LSD NiMH. This chemistry has proven to be pretty much ideal in that it truly requires less diligent maintenance. I generally run these cells through a complete use cycle (ie. down to 1.20 Volt) at least every 2-3 months by default. At approximately 6 month intervals, I run a "break-in", but I haven't panicked if this doesn't happen and am satisfied as long as a "break-in" is performed once per year. For storage, I do the same as for traditional NiMH cells, as above. When removed from storage however, I only run a "break-in" if the cells have been stored for more than six months. Otherwise, I just charge them up normally, but do stick to the "break-in" schedule of 6-12 months.
I don't really use the R&A function very much. What I do find it useful for, is when "good" cells show signs of not holding voltage well under load (voltage depression). A "break-in" would likely be superior, but the R&A function saves time, and if the cells, particularly the LSD variety, have not been "out of the loop" for very long, the R&A seems to work well, and of course is much faster. It is important to note, that even LSD cells will lose their ability to hold voltage under load, when not used for long periods. That has been my experience anyway.
The functions that I use the most with the C9000 are, charge, discharge, break-in and R&A, in that order. I have never used the cycling function, although I have used the similar "refresh" function in the past with my La Crosse BC-900, but don't really use it anymore.
I'll also add that I always perform a "break-in" cycle with new cells, regardless of their specific chemistry, discharging them first at a slow rate. Whether this really matters concerning LSD cells is debatable. My own observations have shown as much as a 150mAh advantage with eneloops, compared to not doing a break-in first. These cells had been "on the shelf" for about two years, and this may have been a factor.
Dave
