TakeTheActive
C9000 Impedance Check Voltage on *CRAP* Cells...
Welcome to the 'Rechargeable Cells w/High Internal Resistance' Club!
What is the C9000 Impedance Check Voltage on these *crap* cells?
Several weeks ago, 45/70 posted a method that he used to use, IIRC, to attempt to dissolve crystals. It's tedious and time consuming (Discharge @ 100mA to 0.9VDC; Charge @ 0.5C for ~5min; REPEAT), but, it sounded viable so I tried it:
Note the eventual drop of C9000 Impedance Check Voltage on Cell #8. Also take note of how much more the BC-900 DISCHARGE @ 100mA (500mA @ 20% Duty Cycle) can get out of the cell compared to the C9000 DISCHARGE @ 100mA (1000mA @ 10% Duty Cycle). Then, look at how long the '*FREE* Duracell Superman 1AA Incandescent Flashlight' DISCHARGE runs (until the bulb is COMPLETELY extinguished, AFAICT) after the BC-900 is done.
I interpret the drops in BC-900 and Superman Flashlight numbers as the dissolving of the large crystals and thus the reduction of the cell's Internal Resistance, resulting in an increase in the cell's Capacity @ 0.2C.
Granted, the average (sensible) rechargeable cell user would just RECYCLE *crap* cells and move on (the ROI vs Time-Invested ratio STINKS! ). But, for those of us with the TIME, and the CURIOSITY, IMHO experiments like these increase our knowledge.
Well, it looks like Cell #3 and #4 have problems... ...I Discharged the 4 last night @ default rates; 2 of the 4 banks showed 0 mah upon completion. I'd never seen this before so set them on Charge at default rates this morning. The same 2 banks showed up HIGH. Strange considering the results above, less than a month ago. I let the 2 batteries rest, then tried charging them in the maha-c204w. Same result, red flashing light...won't charge...
...Strange considering the results above, less than a month ago. I let the 2 batteries rest, then tried charging them in the maha-c204w. Same result, red flashing light...won't charge...
...I wanted to attempt a revival of some powerex 2700s [dated 07-08], that have been more or less storage box queens. I've done a couple of break-ins giving results ranging from 2100-2350...
...I have so many cells that I don't get to use most of them. So they end up spending more cycles "refreshing" than actually powering something. I still have cells that have only been cycled since bought years ago but never gone in a device, sigh...
You guys crack me up...
Who would buy cells and wear them out testing rather than using them in devices...
Code:
Rayovac I-C3 2000mAh AA [B] | #5 #6 #7 #8
09/xx/09 C9000 Break-In: 1600 | n/a x n/a x mAh
09/xx/09 Sears Solar LED Lamp | n/a --- n/a --- mAh
09/xx/09 BC900 Discharge: 100 | n/a x n/a x mAh
09/20/09 C9000 Discharge: 400 | n/a 1549 n/a 1638 mAh
09/20/09 C9000 Break-In: 1800 | n/a HIGH n/a OPEN mAh
09/19/09 C9000 Discharge: 100 | n/a 15 n/a 0 mAh
09/19/09 C9000 Discharge: 400 | n/a 1617 n/a 1676 mAh
09/20/09 C9000 Break-In: 2000 | 1639 HIGH 1655 MODE mAh
09/18/09 C9000 Discharge: 100 | 0 125 4 10 mAh
09/18/09 C9000 Discharge: 400 | 1556 1470 1498 960 mAh
09/11/09 SAKAR Charge: 150 | n/a ~24 n/a ~24tHrs
09/10/09 C9000 Impedance Check: | n/a 1.62 n/a 1.64 VDC
09/10/09 Sears Solar LED Lamp | n/a --- n/a --- mAh
08/23/09 BC900 Discharge: 100 | n/a --- n/a --- mAh
08/23/09 C9000 Discharge: 100 | n/a --- n/a --- mAh
08/23/09 C9000 Discharge: 400 | n/a 1529 n/a 1706 mAh
08/23/09 C9000 Break-In | n/a HIGH n/a n/a mAh#
08/21/09 BC900 Discharge: 100 | n/a --- n/a --- mAh
08/21/09 C9000 Discharge: 1000 | n/a 1396 n/a 1649 mAh
08/21/09 BC900 Charge: 1800 | n/a +1781t n/a --- mAh
08/20/09 C9000 Break-In | 1687 n/a 1698 n/a mAh#
08/19/09 C9000 Discharge: 1000 | 1664 n/a 1617 n/a mAh
08/18/09 C9000 Discharge: 100 | n/a 74 n/a 38 mAh
08/18/09 C9000 Discharge: 400 | n/a 1575 n/a 1663 mAh
08/18/09 C9000 Break-In | 1729 HIGH 1781 3 mAh#
08/16/09 C9000 Impedance Check: | 1.59 1.68 1.59 1.66 VDC
08/16/09 Superman 1AA Flashlight | ~3 ~2 ~3 ~1 Min
08/16/09 BC900 Discharge: 100 | 21 28 8 77 mAh
08/16/09 C9000 Discharge: 100 | 77 54 91 28 mAh
08/16/09 C9000 Charge: 2000:3m | 101 101 102 100 mAh
08/16/09 C9000 Impedance Check: | 1.60 1.71 1.59 1.66 VDC
08/16/09 Superman 1AA Flashlight | ~1 ~2 ~1 ~4 Min
08/16/09 BC900 Discharge: 100 | 22 26 8 41 mAh
08/16/09 C9000 Discharge: 100 | 35 9 47 2 mAh
08/16/09 C9000 Charge: 2000:2m | 52 53 53 52 mAh
08/16/09 C9000 Impedance Check: | 1.60 1.69 1.59 1.64 VDC
08/16/09 Superman 1AA Flashlight | ~2 ~10 ~1 ~2 Min
08/16/09 BC900 Discharge: 100 | 23 28 8 46 mAh
08/16/09 C9000 Discharge: 100 | 47 19 66 9 mAh
08/16/09 C9000 Charge: 2000:2m | 53 54 54 53 mAh
08/15/09 C9000 Impedance Check: | 1.60 1.67 1.59 1.59 VDC
08/15/09 Superman 1AA Flashlight | ~2 ~30 ~7 ~6 Min
08/15/09 BC900 Discharge: 100 | 22 7 11 41 mAh
08/15/09 C9000 Discharge: 100 | 30 2 52 2 mAh
08/15/09 C9000 Charge: 2000:2m | 53 56 56 54 mAh
08/15/09 C9000 Impedance Check: | 1.60 1.70 1.60 1.79 VDC
08/15/09 BC900 Discharge: 100 | 33 RST 16 RST mAh
08/15/09 C9000 Discharge: 100 | 152 125 193 99 mAh
08/15/09 C9000 Charge: 2000:5m | 200 201 203 201 mAh
08/13/09 Superman 1AA Flashlight | 2 15 2 2 Min
08/13/09 C9000 Impedance Check: | 1.60 1.69 1.60 1.80 VDC
08/13/09 BC900 Discharge: 100 | 19 79 37 106 mAh
08/13/09 C9000 Discharge: 100 | 80 13 96 25 mAh
08/13/09 C9000 Charge: 1000:6m | 100 100 100 100 mAh
08/13/09 C9000 Impedance Check: | 1.60 1.68 1.60 1.80 VDC
08/13/09 BC900 Discharge: 100 | 18 93 27 99 mAh
08/13/09 C9000 Discharge: 100 | 54 25 98 16 mAh
08/13/09 C9000 Charge: 1000:6m | 100 101 100 100 mAh
08/12/09 C9000 Impedance Check: | 1.62 1.70 1.61 1.80 VDC
08/12/09 BC900 Discharge: 100 | 10 116 37 102 mAh
08/12/09 C9000 Discharge: 100 | 35 20 82 7 mAh
08/12/09 C9000 Charge: 1000:6m | 90 101 110 100 mAh
08/12/09 BC900 Discharge: 100 | 0 118 41 100 mAh
08/12/09 C9000 Discharge: 100 | 0 167 19 0 mAh
[Bought: mm/dd/yy - HP Camera, GPS, RS Thermometer]
--- Results not recorded
n/a Cell not included
RST BC-900 reset itself when programming new channel
't' Cell's internal (pressure) switch TRIPPED
