Hello everyone I purchased MicroFire K3500R used here on the forum. When I recieved it the bulb will not light when it is cold. The bulb will strike but will not light unless i press the switch many times very fast. After about 20-30 quick presses of the switch it will light up and once it is heated up I can turn it off and on with no problems. Do you think that it could be the bulb that is bad or does this sound like a ballast problem? I was just hopeing for some feed back before I purchase a 100$ bulb. Thx for your help...
