souptree
- Joined
- Dec 24, 2005
- Messages
- 1,175
Scott, I would love an MC2 with the Kingbright Orange emitter if one can be made available to me. My orange A2 remains one of my most used and favorite lights. I have wanted a MilkyCandle for a long time and if there's an orange one out there for me, well I just can't resist. :thumbsup:
No worries, you're not too late. Actually, you're going to get a special treat (hope you see it that way too!)... I was one unit short so your second MC2 will actually be the one I made for myself! It's a Nichia GS based light with the custom-recalibrated firmware just like the others, but as the backup LED this one uses a wide angle Kingbright ORANGE rather than the standard amber LED. The Kingbright Orange 5mm is one of my favorites... the color is IMHO gorgeous and the LED itself gives off an almost shimmering quality when running... very pleasant to look at. Hope that works for you.
No spacer required! The tailspring is on a threaded mount, so you unscrew the spring assembly (not enough for it to fall off, stop just short of that) to run with a single cell, and screw it back down when running with two cells. I personally dislike spacers and adapters because they would just represent one more accessory to get lost... wanted to come up with a solution where the light itself was already outfitted with everything it needed, and that's exactly what we've got with the current design.
On a related note: the nylon cup in which the tailspring sits can be popped off, it's not glued in place... this doesn't ordinarily present a problem because it's not a load-bearing element, the spring tension falls on the machine nut inside the cup, not on the cup itself... it yours ever does get crooked or fall off, just pop it back onto the machine nut and all should be well.
One other very minor note: I'm shipping all these units PRELOADED with 2x123 nearly-spent cells (they register 10% or 20% on my ZTS battery tester)... I do this to keep the spring assembly from flopping around during shipping, also to demonstrate how the unit runs well even on badly depleted cells. Or maybe the whole project is actually my secret plan to dispose of my own spent 123 primaries! (Hee hee.) :laughing:
