Modifying a power failure alarm circuit
Illum
Central Florida, USA
Source: http://www.electronic-circuits-diagrams.com/alarmsimages/alarmsckt2.shtml
Found this circuit online...and looking for ways to modify it to use a 2N3906 instead
I am not going to pay $6 shipping plus $5 fee to buy a $0.35 transistor when I have everything else...since it suggested at any general purpose PNP transistor will do, I have a jar full of 2N3906s so I'm hoping to use these
I believe the difference is the base biasing....but after looking at both datasheets for the last hour and I can't figure out what to change the resistor to, its telling me base cutoff current, not cutoff voltage, which I need for the resistor calculator.
I'm planning to power this with 9V, with the existing layout it doesn't matter whether I put 10KΩ or 3MΩ where R1 and VR1 is...the 2N3906 just will not turn off! :candle:
I hate testing with buzzers...so much:poke:
My understanding only goes as far as
To saturate the 2N3906
assume maximum load current = 100ma, HFE = 100 min
Minimum base current is 1ma, with 30% addition, 1.3ma.
Vin = 9V, the 1N4001 will drop 0.6V, so Vin = 8.4V
R1 is then calculated at
R1 = 9V / (.1/100 x 1.3)
R1 = 6923Ω, minimum 7KΩ
R2 = 10 x R1
R2 = 70KΩ
but in this case, the diagram isn't exactly consistent with the second picture above...I'm not sure whats wrong with it, the R1+vR1 in pic 1 is R2 in the picture, and the R2 in pic 1 is R1 in pic 2, but with two pots set at 7K and 70K but still...no dice
Any recommendations?
xul
MD
Saturation current gain is more like 10. What's the specs on the buzzer?
