chimo
Thanks for running those TIN. Nice job.
Unless Arc (or whatever name you want to use) has a change in heart, we'll never see it. That's why there have been many lights to catch-up with the nitch that Arc used to hold.
Anyway, I agree that it's a good thing the LED is sunken deep vs. sticking out the front end. I've been doing comparision "useage" type stuff in a dark room, comparing my E01 with the Arc. Each one of these E01's that I have are less-blue in the hotspot than what the Arc is. I'll tell ya, it was really nice being about to tailstand the E01 when I wanted to. The only way I get than in my Arc is when I use my Peak pocket tube.
One of my initial concerns with because the LED was set so deeply, the sidespill suffered while doing wall-hunting. In real world useage, it doesn't seem as noticable, if at all. Just like how I thought the SF E1B would cause an issue with it's narrower beam, that turned out to be OK when you actually use the light.
I also like the fact the E01 has a couple flat areas on the side of the battery tube. It makes "mouth holding" useage much easier. I'm still trying to get use to the fact the E01 feels "fatter" when I'm holding it. It should be no surprise, since it is.
It seems to me like the E01 is brighter than the Arc (and stays that way longer) while the curve falls in moon mode.It's pretty obvious that Arc has a much better moon mode, at the Scarface of normal regulated runtime.
Nicely done, Ray - thanks.
I'm confused by your statement, though:
What are you defining as "better"? I guess would be the short question. Thanks.
I think we're splitting hairs here, unless I'm totally missing what you're asking.
