StarHalo
If you think $4 would be skyrocketing just come over to Europe.
Gas prices here start currently at about $8 per gallon.
Depending on how things in Iran and Syria go, we might be joining you soon..
I've seen a 7-8mpg increase on that if I hang a little behind an 18 wheeler. (About three or four car lengths.)
You would probably do even better hanging behind a bus, especially if you can hang a car length or two behind. Not related to mpg per se, but I've gone 50+ mph on level roads on my bike hanging behind buses. I also hit close to 60 mph once behind a large van when I accidentally got on an expressway. I don't even need to hang right behind-a car length back is sufficient, and it gives me sufficient time to react if the driver hits the brakes. Really amazing how much those things block the wind. The only downside is I'm spinning at about ~135 RPM in my top 53-11 gear @ 50 mph, so it's not something I feel like doing for more than a brief time. When I feel like slowing to more pedestrian speeds, I just get out of the slipstream. Once I do that, I slow down like I hit a sand pit.I've seen a 7-8mpg increase on that if I hang a little behind an 18 wheeler. (About three or four car lengths.)
When tailgating a truck to increase mileage, several things come into play. Among them are less turbulence, reduced wind resistance and consistent speed.
An early Prius driver did some tests (complete with wind speed sensors) and found that you still get benefit from following a Semi at a normal distance. The 'wind shadow' extends much further than was expected.
Don't discount the fact that the semi will also tend to go at a more steady speed than typical traffic. Steady speed means less chance of needing to hit the brakes.
Semis also tend to go a little slower. This decreases fuel consumption on most cars.
Daniel
Cruise control helps a great deal as well.
