Outdoors Fanatic
I don't work for Jetbeam, but I suspect that your goose would be cooked long before the LED's. Someone already mentioned (either here or in the Marketplace thread) that they thought the time limit was to protect the batteries rather than the emitter. After running the numbers, I think they're right. Unless the M2S has spectacularly efficient circuitry, it will end up pulling ~1800mA from each CR123A, even fresh @ 3V. As soon as they drop to 2.5V each, if the light stays in regulation it will be drawing ~2150mA from each battery. Most CR123A manufacturers state that the max safe continuous draw is 1500mA, so I'm betting that the 3 minute time limit is to keep the draw from being "continuous". Anyone using the extension with 4x CR123As or 2x 18650s will be ok current-wise, but since Jetbeam didn't go with a four battery body tube, they need to account for the "lowest common denominator".
That's total horsecrap! Have you ever used a powerful tactical-incandescent flashlight in you life, or a HID? A basic SureFire 9P or C3 with the standard P90 lamp assembly gets scorching hot after 10 minutes of continues run. With HOLA bulbs, you can't even touch them after 3 minutes. And yet, SureFire has never put any kind of cell overheating warning on any flashlight or flashlight manual or brochure in its 30-year history. A LOT of SureFire lights draw more than 2A, sometimes 2.7A from each CR123A cell with no issues. Do you know "C" rule? A typical lithium cell can handle up to 2C, a good quality CR123 is rated at 1500mAh = x2C = 3000mAh. But most cell manufacturers will say 2500mAh just to be on the safe side.
The emitter itself, is precisely the reason any half-assed manufacturer would put any kind of continous runtime-limit on a flashlight.
My point is, why are you making all this stuff up if you obviously don't know what you are talking about?
