Dirtbasher
Out of curiosity , what about other lights that are sealed "IPX8" surely they will be sealed tight hence gassing would be an issue getting past the seals?
As far as releasing any potential gas buildup in this light, to hopefully protect the switch button rubber, what I did was remove the o-ring at the tailcap and leave the tailcap slightly loose. I'm not worried about rain water getting in there as I'll likely not even use it in the rain. But that's just me. The light still works and any gas should escape out the threads before blowing up the rubber switch cover. It's just a precautionary measure on my part, as I've had no issues to date with the light or switch.
If gas venting is a major contributory factor, I wonder how the 8aa cell TK41 gets rid of it. (or even the EA8 and D40A)
probably because the cells don't vent? Batteries when treated well normally don't vent. So something is making them produce more hydrogen than can be recombined for the batteries to vent. Ambient temperature shouldn't be an issue
I put four of those in one of mine and it worked fine, but I did not notice any difference in brightness. Oddly enough, I tried 4 rechargeable NIZN cells in it, which are just over 1.8v from the charger, and the light would not power on at all. It was like it had some sort of protection built in from overloading!
Hi,Thank you for your email.
EA4 can be used with Ni-Zn AA 1.6v rechageable batteries.
The normal working voltage is 3--8V
Any question, please feel free to contact us.
Best Regards,
Service Center
[email protected]
SYSMAX Industry Co., Ltd.
Add: Rm1407-08, Glorious Tower, 850 East Dongfeng Road, Guangzhou, Guangdong 510600 China
Tel: +86 20 8386 2000
Fax: +86 20 8388 2723
Web: www.nitecore.com ;
Just to add my 2 cents to the balooning issue.
My EA4W (just arrived) has the serial 3110483540023
Hi gavro,i purchased the "later" version and the rubber switch is not soft from what i have heard on the previous ea4s with issues.To a point it takes some use to the 1/2 press at first due to how stiff and lack of feel,get hang of it eventually but in no way does the button feel the kind of material that will melt easy.
Oh i am more than made up with it too,cracking little pocket rocket
serial-3082183520062
