kaptain_zero
- Joined
- May 31, 2010
- Messages
- 220
Apart from not catering for 2s,4s,5s,6s If it only charges through the balance leads then 500ma is about the fastest you could charge it. Going to take ages on a 7000mah 3s lipo..
The photo clearly shows it charges through the main power cable with a T plug... I use XT60s so that would require an adapter. Thinking about it, I could also make an adapter for the balance port, but if the charger software cannot handle 2 or 1 cells... it's a moot point. Like you, I'll just continue to bung my batteries on a hobby charger.
So... feature after feature is dismiss-able, leaving one to wonder what one is actually paying for. The probes have no calibration accounted for.... I suppose I could grab my Fluke 87V and compare them, but then I already have my 87V out.... and I know it's calibrated, so why bother. My iChargers already have the capability of testing capacity, putting cells into a storage charge and charging them for use. I have 2 iChargers and a Turnigy charger, so I don't need another charger to test cells that once a year when I want to see the state of all my cells.
Nope, I don't see any additional value to this charger... the lower cost Xtar chargers are great, and I would recommend them, but this particular unit was designed by the marketing dept., not the engineering dept. and it shows.
What WOULD be nice is an SV4 with voltage display instead of just % of charge.
Back to the bench....
Christian
