Re: NiteCore Extreme - RUNTIMES, BEAMSHOTS, COMPARISONS, etc.
Glad you are all enjoying the review! :grouphug:
The EXTREME beam shots here and elsewhere appear to have the typical Cree Q5 black donut around the hotspot. I wonder if it is obvious in actual usage as is it is the photographs. Its strange but my second NDI from a more recent shipment had less of this than on my earlier NDI, with which the beam shots of the EXTREME look more similar.
I may be a bad one to ask, but I find Cree rings don't bother me at all in real usage. I just don't notice them anywhere but a white wall!
In terms of degree of rings in beamshots, this often reflects minor focusing difference from one sample to another. If you look at my NDI review, you'll see my pre-production version has much less noticeable rings on the wall beamshot. But in real usage, I can't tell a difference between any of my NDIs.
The issue with the triangular beam at close quarters is probably more noticeable, but I'll need to play around with more when I get back next week.
In my case the runtime on MAX for hot off charger battery is 49 minutes and the same test done after 1 day from fully charged is about 47 minutes. That's more or less closer to your tests.
Thanks Viren, I enjoy your reviews as well.
That's very good battery performance - I presume for an AW protected? I've got 4 AW black-label RCRs (bought at different times), and their performance is all within a minute or two of each other on max drain (e.g. Jet-II IBS). Oddly, I've noticed a lot more variability on my AW 14500 protecteds (some seem to have the same capacity as the RCRs, some are a good 25% or more - one is even 40% longer lasting). So there's definitely some potential for battery variability here.
All my runtimes are done hot off the charger (TL-100) for all my reviews.
