recDNA
- Joined
- Jun 2, 2009
- Messages
- 8,761
The only thing that holds me off is the relatively low throw numbers for so many lumens.
I have a tale of woe for you.
I preordered a TM15 ages ago and waited patiently for it. It looked superb, and was awesomely bright.
Then literally 6 hours after it arrived I had the misfortune if the lanyard slipping out of my hand and with a sickening crack it fell straight onto a concrete floor. Bezel first.
After I'd finished crying I looked at the wreck. It was totally ruined, lens smashed, bezel bent over double, anodizing stripped off. But what struck me was the apparent lack of robustness. The actual light had been about knee height when I dropped it, and yet it was totalled...not exactly 2 meter impact resistant. Also, I know the bezel is thin but it still shouldn't be that soft. It was like mild steel, and it bent in between my fingers with minimal pressure.
Obviously build quality is not as good on this light as I thought.
Truthful accounts are told from memory and are in chronological order.
Emotions take time to process, so truthful accounts generally have the emotions placed afterwards. Story telling puts the emotions in the 'logical' or 'perfect' place, like when reading Stephen King stories. Emotions placed in the perfect part of the story are often artificially placed there for effect.
I also noted that the "sickening crack" came before it hit the concrete.
Your doubters are correct, but I guess I am wondering is why you posted this in the first place? Did you have a bad experience with Nitecore previously? Knee-length fall "totaled" a well made light? No. It did not happen as written.
I have ordered the ThruNite Catapult Flashlight Flip Diffuser
from ebay and will see how it fits on the TM 15 and post review. I love the TM 15, in particular, how it can be used for common, every day uses on low, and then have the powerful lumen high for outdoors. It is solid and feels, as someone else said, more like a "tool" with its rugged design. The on/off switch feels substantial.
I did not have to remove the pins or lever on my Thrunite diffuser. It took a bit of pressure on the lever but it latched down on my TM15 with no problems. And Nitecore does make 60mm rubber diffuser and colored filters for the TM line but I have only found them listed on one vendor, pixxass.de. I know nothing about them.
Same here in fact one of the pins flew out so I took them and the latch off, nice slip on fit now.I removed the pin and lever because when closed the lever was not in line because of uneven tension.
If yours worked without uneven tension, I am glad it worked.
Not the best picture but here is mine. Did yours look different? I squeezed the body shut with one hand as I swung the lever closed when I installed it.
Please could NE1 report what kind of "signal" should come out of the charging adapter?
I know how the charging is supposed to work: the TM15 should be in standby mode (not in lockout mode!), you connect the charging adapter and that's it.
However my TM15 doesnt go into charging mode when connected to the charging adapter, so either the charging adapter is defective (which i hope and believe) or the TM15 has a defect.
Leaving the TM15 aside (in the drawer), in voltage mode my DMM measures 12.3V, and in current mode the DMM doesnt give a steady reading and it's practically 0.00A most of the time. If i can determine that the adapter is defective, it would be easier to get a fast replacement from Nitecore manufacturer/distributor. That's why i have tried to find out, with the help of my DMM, if the charging adapter is defective.
Anyone with a digital multimeter too?
Nitecore TM15 head diameter: 60.00mm (at knurled part), 59.41mm (at stainless steel bezel)
Thrunite flip diffuser diameter: 59.31mm (inner diameter of original untouched rubber insert)
Catapult V3 head diameter: 58.00mm
Thrunite flip diffuser's glas filter lens, diameter: 54.43mm
Thrunite flip diffuser's glas filter lens, thickness: 1.97mm
Eagletac ET55 screw-on diffuser's glas lens, diameter: 54.17mm
Eagletac ET55 screw-on diffuser's glas lens, thickness: 1.96mm
Nitecore TM15 original lens, diameter: 56.97mm
Nitecore TM15 original lens, thickness: 2.07mm
The latch and pins are removable.
A tool this well made should have come with a protective case. I ordered the Thrunite diffuser cap too.
I assume with the tightness of it, it is left on full time, correct?
