Re: Nitecore Tube and V54 TubeVN (5mm, rechargeable) review: RUNTIMES, BEAMSHOTS,...
I posted this thread earlier today before I realized I have a problem with the warm LED on my TubeVN. All the warm LED shots have been redone now that the issue is resolved. Also to show the best natural look to the warm led option I have adjusted the white balance to 4000K using my ZB SC52W for the calibration shots. Previous pictures I had taken had the white balance set at incandescent. So to be thorough I've re-done the stock LED shots as well with the white balance at 4000K. So all these pictures are new. I also added some random shots.
Each shot explains what LED is in the tube, and if the tube is running stock power or if it's the TubeVN with boosted power. To keep in line with SelfBuilts review I did the shots using the same distance from the wall at 0.75m and with the same shutter speed he uses for his shots.
The only difference is I manually set the white balance to 4000K to show the difference in LED tints between the Stock LED and Vinh Warm LED option.
All beam shot were taken with the highest setting on the light.
0: Calibrating WB was with my SC52W L2 using low, medium 1, medium 2, high 1 and high 2 Li-ion @ 500lm
1: Stock Tube with the stock LED
2: TubeVN Boosted
3: Stock Tube with warmer LED
4: TubeVN Boosted with warmer LED
5: Side by Side with stock Tube and TubeVN both with warmer LED
6: Other Random Shots
The remaining shots are collages with direct comparison of LED combinations, boosted and non-boosted noted in the pictures.
Details:
Camera: Nikon D-90
Lens: Tokina wide angle 11-16 f/2.8
Text added with IOS app Phonto
Some editing was done with IOS app PS (Photo Shop) Touch for collages.
Pictures were resized with IOS app BatchResizer for faster upload and downloading.
Pictures were uploaded with IOS app PhotoBucket
All work done on an IPad Mini Retina
Enjoy..... Thank you,
Scott
Note about the reference shot:
I know the basement wall looks a little yellow, but believe it or not it's a pure white. It's nothing but the cylinder white moisture prevention sealing paint. All the other walls in my house are and off white. The reason it looks yellowish is because of the flood lights I have installed in the ceiling light receptacles. All the lights in my house are LED and most appear yellowish on the warmer side.
