I couldn't wait to get mine, but after carrying it for 3 days I went back to my RRT-0 with XPG-R5. It's a wonderful light, but the control ring bumps drive me nuts. I really didn't think it would be an issue, but it really is for me. It's just personal preference of course, but I'd thought I'd share it non-the-less.
Pulled mine out to use a couple of times, and the battery was dead. Didn't think much about it as I knew there was a drain, but when a battery was drained in just one day after very little use (and on low levels), I started checking. I've gone through three different almost new AW batteries, and each time the battery was dead in 24 hours, even though it was not being used. And yes, I am making sure the ring is all the way to off. So, looks like I will be returning mine too.
"The smooth reflector is annoying, but apparently the big competition right now is to see who can make the smallest thrower."
In that case they're using the wrong emitter. Nothing throwy about a small XM-L light....though the EYE10 does ok (7k lux at 1m by my testing) through raw power.
And now that this thread is half a year old,is the Eye 10 still the smallest torch putting out 260 lumens on a single CR123 cell ??
Feel like I need to post this, since I posted something negative about this light. I have an Ultrafire battery that works just fine in the light, which doesn't make sense since the AW brands are obviously better and more reputable. So I need to chalk this up to user error I think. Maybe I didn't charge them all the way, or maybe somehow it wasn't turned all the way off. I don't know, but it looks like I wasn't as thorough in my testing as I thought I was. Sorry everyone, and my appoligies to Niteye.
.....Is it possible to easily remove the lanyard attachment swivel in the tail of the Eye10? I plan to remove it and epoxy a magnet or two in the tail so I will have the PERFECT EDC light for me.....
In what circumstances do you use a magnetic light?
I service copiers and printers for a living (in my 25th year) and being able to stick my light to the steel frame or innards of a machine while working on it is priceless.
That does sound extremely useful.
I actually found some 3 pound pull 1/6" thick x 1/2" dia. magnets on Amazon http://www.amazon.com/dp/B0012ATDD2/?tag=cpf0b6-20. I will just remove the lanyard attachment and epoxy 1 or 2 magnets in the end. I'll use the top hole on the clip for a lanyard attachment point. Can't wait to get the light in a week or so I can mod it into my perfect EDC.
I am interested in hearing about how you remove the lanyard attachment post. I thought it might be a press fit. I bent an old allen wrench to insert into the hole and used a pair of pliers. I can not get mine to turn. A lathe might be the best method for removing it.
Nice work srvctec. How firmly do the magnets hold it?
Isn't the lanyard post screwed in? I will have a closer look at mine, but I thought there was an optional glass breaker at some point that could be swapped out. Might be wrong, so will have a look later.
