More great info to learn
I was wondering about the LG INR18650-MJ1. Are those also supposed to be charged with the 3.6V setting on the VP2?
'Multi-quote', better than a 'multi-pass'.
Yes, all 3.6v/3.7v cells which charge up to ~4.20v should use the 3.6v setting on the VP2. The 3.8v setting is meant for the 4.35v cells like the Sanyo 16650 2500mAh cells, or my LG D1/E1 18650s.
There are others, but all of the cool kids were running them a few years back and Xtar built in that algorithm for 'us'.
The 3.2v setting is for 'storage voltages' on 4.20v/4.35v cells, or when using LiFePO4 3.2v cells. The off the charger voltage on this setting is about 3.6v-3.65v, which is a good 40-50% SOC level to get your li-ions to, before putting them in the fridge for storage.
Every time I think I have this figured out it seems like another question comes along. After resting overnight, two new batteries I charged yesterday on my VP2 were indicating 4.17v and 4.18v today. Does that sound right or should they be 4.2v? I'm thinking I read that this is OK and more healthy for the longevity of the batteries.
Thanks again.
Remember, the algorithms terminate the charge at 4.20v (+/- .05v), but the batteries once removed will settle. How much they settle depends on the condition of your li-ion cells and NiMH batteries. If you've got 300 cycles on an 18650, you might get a settling to 4.16v, or less. I have some 5 year old AW ICR 16340s and they come off various chargers at ~4.17v, if I'm lucky, then settle down to a 4.10v-4.11v in less than a day.
They're old, but still have some usable capacity left (400mAh @ 500mA), so I keep them around.
Still, some chargers undercharge and some slightly overcharge. Undercharging is better for the cells long term. I recently bought four Liitokala USB chargers: two 100 single bays and two 202 double bays. They're functionally identically but for the extra bays.
Both of the dual bay 202s undercharge either 4.20v cells, or my 4.35v cells, more than just accounting for loses (in my mind) due to age. However, both of the single bay 100s overcharge my various cells, to the tune that on my RatShack 22-805, I see 4.22v-4.23v regularly.
I'm somewhat new to this stuff, but I can count the times on one hand, where I've seen a voltage greater than 4.20v.4.21v after a green light. Hell...I even have a NiteCore i4 v.2 charger that notoriously overcharges and it works fine, so go figure?
Chris
