Charles L.
We all have different interests, tastes and uses, of course, so I'm just curious to see how we settle on that favorite lamp.
My headlamp uses are: surgery (small animal veterinarian here); house maintenance projects; auto/boat maintenance; dog walking; camping; night time mountain biking. We have a dedicated head lamp/magnification loop at work, so I don't consider that one mine (although it is indispensable for working on cat or toy dog teeth). I also have dedicated lights for biking. For the other, recreational and household uses, my order of preference for my headlamps would be:
1. Armytek Wizard Pro warm: great tint and range of outputs; great beam pattern; great battery longevity; can detach and use as hand-held light; top button is easy to use; not too heavy; incredibly versatile.
2. Zebralight H600F: equally great range of outputs and more intuitive UI than the Armytek; lighter than the Armytek; similar battery life and hand-held use potential; but side button is a bit harder to operate, and tint is not as nice (should have purchased the warm).
3. Black Diamond Spot: bang for the buck is huge with this light; super light and comfortable on the forehead; infinitely variable output within its range; but doesn't go anywhere near as high or low as the top two; flimsier construction (lightness has its price); flood and red beams are too dim to be useful unless it is truly dark outside.
4. Black Diamond Storm: more water-resistant version of the Spot: but water resistance comes at the price of higher weight (still very light) and much stiffer switch.
5. Nitecore HC50: nice beam pattern; robust construction; good variety of output strengths; but too easy to switch modes when turning the light on; and too heavy to use without top strap. My least-used headlamp, this one is kept in the car.
6. LED Lenser SEO7r: light weight; variable flood/spot output; red LED is bright enough to be useful, but not adjustable in output; but rings in beam are too distracting, and wide/flat design does not fit my head very well. The only true disappointment in the bunch.
I could pare down to the Wizard and Spot, and be satisfied.
