Hey Poppy, It's roughly $50 cheaper to have mine rodded out than to buy a new cheap one. My original is two flue and the new one is higher capacity with 3 flues.
I almost forgot- those original non aluminum radiators in old vehicles like mine are expensive to replace- like maybe $300-$700, so if I want to keep it original rodding out is the way to go. I just want it to work well whether original or not.
Mike, since you already priced it out, I guess you made your decision. Rodding definitely works, and if those engines have a problem with electrolysis, then you are better off without an aluminum radiator.
My brother in law's 1986 D21 EFI nissan hardbody pickup with a 4cyl won't idle or idles rough and unstabile. It might be a bouncing idle. It is intermediate I think. He thought it was the old gas where it had been sitting up, but it does it now with fresh gas in it. Seems like those early EFI trucks suffered from this and folks would just idle them up enough that they wouldn't bottom out and die. It is the same motor as my 86 720 pickup except mine had a carb on it.
I am not familiar with nissans, although, I am with Fords.
1. vacuum leak is probably the most frequent cause of a surging idle.
2. fuel pressure, a weak fuel pump, clogged fuel filter, faulty fuel pressure regulator
Early EFI Fords had a two pump system, a low pressure high volume one in the tank, and a high pressure one attached to the frame closer to the engine.
3. faulty TPS throttle position sensor... that's the least likely of the three. When it goes bad, it will more often give a HIGH idle.
4. edit... I forgot to include your IAC idle air control module
5. electronic ignition module.
6. That engine is old enough that capacitors in the engine control computer may start to fail. You might pull it and take a look for leaking capacitors.
A Haynes, or Chilton's manual should walk you through how to test most of the components mentioned above.
Beyond that, I am sure there are many Nissan forums, where members help members troubleshoot their cars/trucks. I suggest that you find a good one (one where there are some knowledgeable people who help out, vs one that has members who just blow smoke).
Certainly, pulling engine troubleshooting codes (after looking for a vacuum leak) is a great place to start.
Did you pull codes?
What were they?
This is my daily driver for now and I'm also dealing with water in my gas the way it is running. Was doing fine this morning near empty on the way home and I put some more gas in it from another station instead of where I originally got the bad gas, but it is back to bucking like a mule on the highway.
Water settles to the bottom of the tank, and since the gas is pumped from the bottom of the tank, the water, if there is any is the first to get pumped out. Therefore... full tank, or empty tank doesn't matter when it comes to pumping water from it.
Unless your County was under water, it seems very unlikely that you could have gotten bad gas from two different stations. I suspect that your problem is with YOUR truck, and not from buying bad gas.
On a carbed engine if I remember correctly, fuel pressure should be between 5-7 PSI. Check the specs for your truck/engine. Also take a look at your fuel line. I once had a rubber hose that connected my gas tank to the metal fuel line. It dry rotted out, and caused a vacuum leak. It allowed enough fuel at idle, and low speeds, but not at high way speeds the fuel pump was sucking some air into the fuel line. The engine bogged down on the highway.
If you are convinced that your problem is water in the fuel, pull your fuel filter, and dump it into a clear container, and examine it.
