I don't have the extender, but I wouldn't be worried about using it. The light handles 2xRCR just fine, so it will do equally well on 2x18650 - with much longer runtime. Of course, you should not attempt 4xCR123A/RCR since the circuit is not designed for it. But I see no reason to be concerned about 2x18650.Many thanks for this great review SB. As always, your review has always been helpful. Would like to know if you plan to test this light with its extender. Been thinking of getting an extender but still having second thoughts. Am waiting for someone to make a review using it.
Depends on the flashlight, and whether there is a reverse polarity feature in the circuit to prevent damage. If your light works normally, then I'm sure there was no damage done. But I would try to be careful to prevent it from happening again, just to be safe.Hi Selfbuilt, i put a 18650 battery, at the wrong side inside the M2X, for 6 seconds, stupid me........but is that not negative for the flashlight itself=
Sometimes, i put it in, at the wrong side of the battery, hope its not damaging-negative, for the flashlight att all....still functionate very good.
You mean, that even at the lowest mode, the Olight M2X UT, can be to intense, when mounted on a bike, if pointed straight forward=
Thats 5000 cd...is that so much.......its a bit more intense, than the high setting, on my fenix E21.
Please explain, the low mode, on the Olight M2X.
But im very happy with the light...its a bit more intense, than my fenix TK61.
With the M2X you've light at a tight focused point. Because you have light on such a small area, you're eyes will focus on that, which causes 'tunnel vision'. You'll miss out on stuff outside the hotspot which can cause problems.
Thank you for your help kj2.
1 Is the lowmode in your opinion, of the M2X, also blinding for the eyes, when have it on the bicycle, its even more intense, than the Fenix E21.
2 Do you enjoy your M2X........
No specs about "waterproofness", as opposed to the IPX-8 of most modern, quality lights.
No lanyard hole in the tailcap even though the light comes with a lanyard.
Sarge beat me to it. It's true there are no waterproof specs on the package, but the official Olight website does report IPX-8 to 2m for this light. And there is indeed a lanyard attachment point on the grip ring.There is a lanyard hole in the tac ring, and it is ipx8.
It's not designed to, and I don't think it would work very well even if you could make it fit - that's a very big head that will get in the way of any pocket clip.This Javelot not come with pocket clip, so is M3X Triton Pocket clip can use on Javelot?
You can certainly use it any time - but don't expect a very visible beam at any distance in daylight. Again, you can use the typical daytime cd values given in my post here to help guide you.You can easily use it at daytime, under a cloudy sky, at highnoon. The hotspot projects easily, on buildings, trees, at medium distance.
Is this normal, with just under 200 kcd, Selfbuilt-others.
