witness
Re: 2 User Questions
Thanks everyone, I thought I had a defective light.
I like my newer S1 UI that doesn't memorize moonlight and high since there's already short cuts to them. But my main wish is for Olight to just stick with one UI and keep it consistent.
As far as I know, there is no direct way to access the secondary brightness level. You have to wait for Turbo mode to step down.
Finally got my replacement from GG yesterday and this ones works spot on, no problems with switch at all (Thanks Going Gear for your great service!!). In fact I was so tickled I ordered two 14500 Olight 750mah batteries to put in it from them.
Of course I mention one little problem I had with GG and someone has to jump in a claim how great they are. I'm not so sure how replacing a defective product is good service. It's expected and something you have paid for.
On the other hand I do expect a dealer to know their product and not just say whatever they think the customer wants to hear in order to make a sale. I didn't mention it before but...as a point of fact it wasn't just one thing they misinformed me on, it was three:
1) the owner told me I could access the 300 lumen mode of high directly by utilizing the memory feature. (not true)
2) the girl who answered the phone on a different occasion told me that the light could sustain it's 500 lumen output for 1.5 hours. (when in fact it can only be sustained for 1.5 minutes)
3) the owner told me that AW RCR123 750 mAh batteries would work. (they do not)
Thanx GG for the not so great service!
Sorry you have had bad luck with GG. I've always been pleased with their service, rather it was replying to question on a product via email, telephone conversations, super fast shipping and warranty claims. I guess they could have told me they have to send my light back to the company and it would take 6 months turn around. It seems everyone has different experiences with different company's.
hmm... curious, let's find out. I have some old AW ICR123 around for my incan G2, let's do some testing......
You are hitting the protection circuit on the battery. That function is designed to keep the light/battery from overheating.
As it turns out the light now cuts out after only a second or two and...
Cell | Current Draw |
Old AW ICR123 750mAh | ~2.7A |
Old AW IMR16340 550mAh | ~2.7A |
New Olight RCR123A ORB-163P06 | ~1.8A |
Fresh EagleTac Primary CR123A | ~1.8A |
Fresh Energizer CR123A | ~1.8A |
<snip> ... Also, another user had asked that I take an amperage reading at maximum output, and I got around 1.8 amps, even fluctuating as high as 1.9 amps
A little worrying seeing as primary CR123's can safely put out around 1.5amps continuously.
I measured with a bench supply how many amps my S1 pulls in the brightest mode:
Ah-Ha! Thank you so much for the heads up :thumbsup:. Looks like my old AW cells Voltage sag faster under load and below the nominal Voltage, thus S1 drawing a lot more current in order to maintain the high output, in doing so, the protection in my old AW ICR123 750mAh got tripped. Haha! That's interesting....
CPF member Wet took out the battery and hooked his S1 up to a power supply, resulting in the following plot:
Great! now I can use S1 to tell if any of my RCR123 has aged and need to send for recycle. but... oh sh*t... that means I need to replace ~16 pieces of my old RCR123... :mecry:I just got some brand new AW 16340's have one in my S1 and its working great
Thanks for the heads-up. :thumbsup:I should mention that even original Olight's RCR123 gets protection tripped at max power if a battery is discharged to some extent. In low and medium it's OK, but high activates battery's internal current protection.
take it easy man GG is the last retailer you want to lose it with. Keep your cool and Marshall will make sure you are taken care of
