Hi
Yes they are 940nm you should be able to tell that by the MINIMAL glow as the 850's are readily seen when looking directly at the emitter which should not be done for more than a VERY short time. I don't think he originally stated which nm but since the emitters I use are now the same power rating for both 940 and 850nm I always use 940's and specifically bought the newest for his order.
I am sure they are 3 level or else i believe he would have sent it back. Turn the light on and off faster than 3 seconds to change levels, once the light has been on for 3 seconds that level is stocked to memory once stocked to memory you have to double click it since first click will return to stocked level.
I can leave the reflector loose but understand you will then have limited warranty since shorts circuits and damage to the emitter is quite easy but it is not a problem and I am sure you will have no problem. These emitters are a bit more delicate since they are direct mounted to the pill making them easier to knock loose. If I use a MCPCB mounting system they get extremely tall.
$45 plus $5 for 1st class int.
Thanks Dave, would it be possible for you to scuff and spray the reflector black and still bond it then? I am very pleased with it's performance behind a DX lens that has not been blacked (because it's nobby's not mine lol.)
I'm going to post a link to this thread on the airgunforum thread where the aspheric lens topic is being discussed, partly in relation to your units:
http://www.airgunforum.co.uk/forums...inal-suggestions-before-ordering-parts-3.html
What power does this draw please?
Dave
