nailbender
Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / P60 modules (part
Hi
Your best bet is to order one of the 5 levels with 3 lows and med and high. This would give the best options allowing you to use the lowest or highest settings.
If a single level is needed the best I can do is about 4 hours and that is reducing it to 350ma which will not be a very bright light. I don't have measurements on what it would be but certainly not bright, somewhere between low and med on a conventional 3 level driver.
1400mah primaries simply don't go far.
Dave
Hi Dave
I am conisdering a single level Nichia 219 to go with 2x CR123A primaries on a Solarforce 2LP. Can you help advise what is the lowest AMP your can go to help extend the runtime to about 5 hours pls?
Thanks
Don
Hi
Dave
