Balancing simply ensures that all the cells of the pack are equally charged.
No it's not required and no the lack of it will not kill the pack. It may shorten the life of the pack, but it's not life threatening.
Just "charge" you pack with the + and - leads and don't worry about balancing.
Hi guys just doing a burn test using this pack , what is the procedure for burn time, do I just keep going to the light goes out...or turn of when the battery reaches a certin AMP ? I'm thinking the PCB will cut the light of... Don't want to damage the pack... Tony
Could be, although I would expect with 2500mah cells to be more like 4-5 hours. Cycle the switch on and off and make sure it's on the high mode. That is a 5 mode light. Three brightness and 2 strobes.
Didn't know that this head had 5 modes,:twothumbs cus I just have a on/of toggle , but turning on/of I just noticed that it can be changed...
Pretty sure it's on the brightest mode , went to bed after 7 .10 min hrs burn time , continue the burn time today.
Tony
Today I started to finish the battery Pack burn time I end the discharge at 8hrs 30 min...
I am surprised at the length of Burn time, won't need to charge to often .
No mate I had it on the brightest setting , just need to take for a dive tomorrow .
How do you clip on a bolt snap Hector, was going to attach to the gland with zip tie?
maybe not use my good man handle looks a bit bulky with my Meg?
Tony, you would need to clip the snap to the handle. I am not sure I would clip it where you have it as it could cause some strain on the cable. Good luck with it tomorrow, looks good!
