Hello RobbW.
I use a dumb charger to make the forming charge to my cells.
In my case it charges with 270 mAh so if you buy a similar charger you have to charge your 2700 mAh cells 14-16 h. Dont forget to make them empty first.
Here:s how to calculate by Silverfox:
[font="][/font][font="]Battery manufacturers state that it takes 14 hours to charge a battery when the current is set to 0.1C. If there was no loss, it would only take 10 hours. This gives us a nice ratio to work with. Take your 2400 mAh cells and multiply them by 1.4 and you end up with 3360 mAh. If you are charging at 500 mA, you simple divide the 3360 by 500 and end up with 6.72 hours as the charge time.
We all know that the capacities of these cells are exaggerated, so I took the 2400 mAh and figured you would be good to get 90% of that. Now we have 2400 times 0.90 which is 2160. Multiply 2160 times 1.4 and we have 3024. Divide 3024 by your charging rate of 500 and we end up with 6 hours and a little change.
Heat should not be an issue with this type of charge, as long as you shut the charger off at the end of 6 hours. If you wait for the charger to detect the peak, you may cook your cells while the charger continues to search for the end of charge signal. This is a problem with the first charge on a new cell, or on cells that have been in extended storage. Once the cells are "broken in," they tend to give a good end of charge signal that the charger can trigger off of and stop the charge.
Anders
[/font]
