davidefromitaly
I just did a test on a cell that was sitting for 2 months after a charge
Test parameters - discharge at 1350mah down to 1.3v
Capacity tested right after charge - 1175mah
Capacity tested 2 months after charge - 1121mah
That's pretty damn good charge retention right there. I should mention the voltage throughout the discharge curve was about 0.05v less than when tested freshly charged. Though it is still putting out far more voltage than a nimh in any state.
Powergenix replaced my damaged cell with a set of newer and supposedly improved ones. I'll be putting those to test soon.
95% of capacity retention after 2 months... thats great!!!!
when you do a discharge test consider the power, not the current, cause the voltage is different. when you drain 1A from a ni-mh battery you get around 1.2W of power, for take the same power from a ni-zn you must drain around 750mA of current
