JimmyM
Functioanlly, yes. You specified the voltage correctly.Correct me if I am wrong, but aren't the programmed voltage "slots"
#1 and #2 supposed to be the only ones that work when all the other "slots"
are 0.0V as I had on my program detail form?
However, when the programming is done, the unused levels (set to 0.0V) are commented out, not set to zero.
I'm getting the files BVH used to program your regulator to see what happened.
below is a clip from on of the config files for another regulator.
/* These are the LEVEL1, LEVEL2, etc levels as volts.
If you want only 2 levels (low and high) comment out LEVEL3, LEVEL4, and LEVEL5.
If you just want ON-OFF, comment out LEVEL2, LEVEL3, LEVEL4, and LEVEL5.
LEVEL1 MUST ALWAYS BE DEFINED.
Also, you can set the values in descending order, so the first level is the highest.
#define LEVEL1 30.0 // 30.0 Vbulb
#define LEVEL2 29.0 // 29.0 Vbulb
//#define LEVEL3 27.0 // 27.0 Vbulb
//#define LEVEL4 25.0 // 25.0 Vbulb
//#define LEVEL5 16.0 // 12.0 Vbulb
In this example, only levels 1 & 2 are in use.
