Tomas
Banned
Peter, I do not intend to debate, and certainly do not intend to try to dissuade you from your beliefs, but you did, in fact, miss entirely the thrust of what I said above.
At no point did I express a "Pro-Choice" philosophy. What I was discussing was only how you felt you had a right, a mandate, to enforce on others what you believe God, in your interpretation, said was right or wrong.
I disagree with that. You have a right to believe as you will, but you have no right, God granted or otherwise, to control other's behavior.
You may try to convince, exhort, yell, babble, pray, or use whatever means you may have to try to convince others that your way is the only right one and your intrepretation the only true one, but you do not have a God given right to force another to bend to your will.
That is what you were suggesting in your first post - electing representitives to force others to behave as you think they should in this matter. To enforce YOUR beliefs. (Doesn't matter if I agree or not with your belief about abortion, only that I disagree with your assumed right to force others to follow your belief ... )
According to Christianity, God granted each and every one of us the ability to choose between Him and His rules or to choose to turn away. This is his plan. He could certainly have created us to have unswerving devotion and faithful following of all his precepts. He did not. That test is necessary to His purposes.
All I intend to discuss in that one fine point, not the rightness or wrongness of abortion, murder, blasphemy, coveting, worship, or anything else.
We each must make our own choices, must decide for ourselves how we will spend eternity.
Yes, it is proper to try to help others understand what is right and wrong, to guide them, to try to help, but not to force others to follow your beliefs - it must be of their own free will.
(last post on topic)
