Originally Posted by Dealgrabber2002:
If it's not too much to ask, can you run the medium test again with a different cell? An email from Trevor said they ran it 50% and that's the result they got. He said it might be the battery.
It's confirmed... it was a typo... only 8hrs on medium... not 18 hrs...
I ran the MiNiAA on medium on a different Eneloop, as suggested. I pulled a different cell, filled to capacity at 1.45v. This time the results were: 6 hrs 11 mins until the fading spot was quite apparent--almost exactly the same as the first run. The light stayed in regulation with fairly constant output for nearly the entire time (I stopped it at 3 hrs 22 mins to go to sleep). At 6 hr 21 mins the battery was drained to .91v. After a 20 minute break, the voltage rebounded to 1.11v and the light ran for another 3 1/2 mins on medium before fading to a low low.
If one were to use a 2650 mah my calculation is that you'd get 32.5% more runtime, which would translate into close to 8 hrs, the revised 4 Sevens numbers for medium. So, if you were to use Eneloops as your regular NiMH battery, as I do, expect about 6 hrs on medium. The pleasant surprise was that I found about 2 hrs 20 mins with the Eneloop on high, much greater runtime that the 1.2 hrs listed on the 4 Sevens website.
IMHO, this is still amazingly good for a single cell AA light.
Originally Posted by JCup:
I've been pleased with the Quark, it works well, but I have to say it is a little less bright than the Nitecore EZAA R2.
If you hold the MiNiAA side by side with the Nitecore EZCR2 (that's the EZ Nitefore I have) at a distance of about 2 meter from a wall, you can easily see that the size of the hotspot for the MiNiAA is about 4 times larger than that of the EZCr2. From my point of view that makes it more practical in a close in situation, say in the house, since it puts out a much wider range of light. I don't know for certain, but would expect the situation to be much the same for the EZAA.
I also compared the light on medium on a wall, at about two meters, to my old Fenix L2D2, which claims 20 lumens on low. It seems about the same intensity, but the hotspot again, is about 4 times larger and therefore much more useful.
