It looks like an electrician's light.
I recently scored yet another railroad flashlight.
This one is an unknown brand but was made as a promotional for Norfolk Southern.
I got it on eBay along with other Norfolk Southern memorabilia.
The switch is slightly damaged and in order to use the flashlight, the switch has to be pushed and held all the way up.
Any idea on how to repair that issue?
Nice score EJ.
Some sliders move a rod forward to touch the reflector or move away from it. Over time oxidation may be such that it has to be slid further to reach a clean spot. Perhaps the point of contact has bent just enough to also cause the issue. A slight re-bend of the tip of the slider back towards the center may be in order.
Sometimes the little 'ears' that fasten the switch plate itself to the sliding rod will 'unbend' allowing play in between. A flat tip'd screwdriver can bend them back to factory in some cases removing the play between the two and re-introducing positive contact points again.
If that don't help ya, pm me and we'll take it from there. Probably something pretty easy to fix.
This is the final [tubular] railroad issue flashlight I have in my collection. It is a Bright Star 575.
Technically this particular one I have here was never used by any railroads (I bought it at my local Motion Industries branch.) However I have seen this Bright Star model used by a Kansas City Southern engineer in a You Tube video and I have also read about it being used by railroad electricians.
[/URL][/IMG]
[/URL][/IMG]
