Does anyone know the exact weight of this headlamp? I am a lightweight backpacker and want a 1 watt light with diffuser that is lighter than my 96 gram Petzl Tikka XP.
Thanks in advance.
I just weighed an Energizer alkaline and an Eneloop AA battery - about 25g each. Two AA batteries and the lamp still come in under the original 96 gram limit... Replacing the (pretty well useless) blue LED with a decent white one would provide a nice low power option to conserve batteries, assuming tinkering is an option.Its lightweight, but because battery life is short at two hours with little warning when it is dead, you will have to carry spare batteries
right, but iirc the pt fuel is only 5mm leds...that'd be like saying OP could use the rayovac for the whole trip on the red / green option.
Yeah, the previous pages of this thread cover that.This light is not easy to mod without destroying the casing
we're gonna need to see some pics of your mod and some beamshots of the seoul through your headlamp. :thumbsup:Yup, check my posts and f22shift's. Key is a thin hobby saw, and pre-gluing a fine bead of hot glue to the case edge on re-assembly, then using a heat gun to activate it after it is together for final adhesion. It is brain surgery for sure, but I love mine with a Nichia DS in the blue position, and a Seoul in for the Lux. After you deal with the case cutting, the LED mods are as easy as any.
f22shift has a gallery of pics of his upgrade at https://www.candlepowerforums.com/posts/2302093&postcount=94
