2AA-2D lights - 2AA bulbs ~2.2-2.3V ~0.6A, or should I stick to 2.4V 0.5A bulbs? Or just get a Magnum Star, or a Xenon from Dorcy? At voltage this low, it doesn't really seem to make much difference. It's hard to get much light out of 2.4v, short of using the Nite Ize LED drop-in. I once tried a 2.4v 1.2A Krypton bulb, but the results were pretty lame.
I have a lot of 2D lights, and while your light really seems awesome, I both want to use the D cells in them already. However, if I do decide to do an elementary mod, I will definitely try your mod out.
3D lights, again either a Magnum Star or a Dorcy Xenon, is there a difference between them? Dorcy has them for $2/2 and Mag sells them for $3 each! Someone else here on CPF once had good things to say about those KPR-103 Oscillite Bulbs. I'd give them a try.
6V Lantern - I will run it off the extra 3 cell Mag bulbs I have, along with the 4.8v bulb that came with it, since I have no use for it. Good plan. One thing to note; If your Mag bulbs are older than about 10 years, they will pull around .70 amps as opposed to .82 amps for the newer bulbs.
6D lights - probably a 5 cell Maglite bulb. Good; 5 cell Mag Xenon will be quite a bit whiter than either 5 cell Mag Krypton or 5 cell HPX-53 Xenon.
Anyway, these are still preliminary, I'm just really curious about the Xenon bulbs. The Mag Xenons tend to be whiter than than other brand Xenons; but considering the low prices of some of the Dorcy Xenons, the slight color difference may not be worth the extra money.
Your suggestion of Lithiums are also good, I would love to get some, but I'd have to get AA-D adapters too... I can't believe the discharge curve they offer, but I'll have to look for the runtime, and cost vs. normal D cells, as well as against normal AA cells...
Finally, anywhere I can get 3AA/4AA to D cell adapters? I'll let someone else handle this one, as I've never bought any.
And also, I had a brainwave, after looking at discharge curves, I see that alkaline batteries actually have a decent lifespan left in them even down to the 0.9-1.0v level, what if I swapped out a bulb rated 1 cell less in them after they've dimmed on the stock bulb, how will performance be like?
ie, a 3 cell light will run 3.6v over its useful life, but then it'll drop to 3.0V or so, at which time the 3.6v bulb will look dim and orange, what if I then swapped out a 2.4v bulb into it? I've never thought of that before, but it seems a reasonable idea. I don't know what kind of current draw a battery in that depleted state could support, so I think I would stay with .5 amp draw or less 2.4v bulbs.
I can't believe I've caught onto this more than LEDs... just trying to figure out all these bulbs took so much more time than figuring out a LED light to buy, but it's pretty interesting!
