It's a old thread but I think this is the solution , also available in green:The OSTS Night Master is an extremely intense long throw LED flashlight for hunting and law enforcement work or wherever an extremely powerful handheld and pocketable thrower is needed. The collimation type is aspheric which features a spot only type beam without any side spill light.
There is always a lot of talk about lumens in regards to flashlight power. Keep in mind however that how many lumens a light has does not give any indication of how well a particular light will throw or how far the beam will go. When it comes to throw the measurement you want to know is the candela as noted in specs as cd or Kcd which means thousand candela. The OSTS Night Master RED is rated at 52Kcd which written another way is 52,000cd. This is 97% more intense than the stock Dereelight Nightmaster which measures at 26.4Kcd. Both measurements taken using two cells as opposed to one 18650.
This listing is for the RED light version of the OSTS Night Master. There are also White and Green versions available. An infrared version is in the works for those who need long distance night vision scope illumination.
