Is there momentary?
No. Should make it a perfect light for me....Is there momentary?
I tried. No success. ...Do you know if the EA81's cell config is 4S2P like the EA8? Meaning can it run off of just 4 AA's as seen in this review: http://www.candlepowerforums.com/vb/showthread.php?358879-NITECORE-EA8-Caveman-Review-(8-4xAA)
I suspect the restriction to all 8 cells is because of the XHP50 LED and the much higher current draw as compared with the EA8. I had the EA8 for several months and never wanted to use only 4 cells. I needed the run-time for the wide-open spaces when the output was on max all the time.
This makes sense. The Cree XHP50 comes in two flavors. One has a forward voltage of 6v; the other, 12v. I presume that the former is the one that is used in flashlights. If Nitecore wanted the Nitecore EA81 to have the capability to run on four batteries, it would have to design a boost driver for it. By using eight batteries, Nitecore can achieve the necessary voltage using a buck driver.
I do not know any facts about the driver, so this is only speculation on my part.
I haven't done any formal run time tests, but I use this in a 3rd world country almost daily, and it's an incredible light. Recently used it on a jungle trip and it impressed me even more. With the Nitecore diffuser, it's perfect for me.Ps how are your run times for example high mode? Do you get more or about the same stated runtime?
Yes, those are the ones. They fit my EA4, EA41, and EA8 just fine.Thank you to both of you.
Are these the AA 2500 LSD Amazon batteries you talk of?
http://www.amazon.com/dp/B00HZV9WTM/?tag=cpf0b6-20
Just a question. Why is there a doughnut hole in the hot spot on the ea81? Even not up close, it has it, unlike the ea4?
