Just received my Scorpion today, this is the first time I got to play with this type of tail switch, so please pardon me if my question sounds noob.
1) It was mentioned in your review there is a removable inner plastic tube inside the battery tube, but there is no mention on what it actually does. Is this some kind of isolator for the magnetic switch to work? And when I shake the light without battery inside, the tube moving up and down, is this normal?
2) I noticed there are some heavy lube inside the tail-cap around the base of the spring, and also the inner battery tube near the tail-cap. I wonder if lube is really necessary at this part, especially with that much of it? I have a habit of cleaning and re-apply lube with all my new lights, but I will leave this one out until I am sure how much to and where to apply.
3) I got myself the turbo head as well, by comparing the regular and the turbo head, I realised that the glass on the regular head seems biffier than the one on the turbo head, by tapping on both of them and judge by the sound they made. Anyone noticed that as well? May be its just that the glass on regular head are smaller hence sound heavier.
Since I am at work now and do not have any 18650 battery with me to test it, so lets share my first impression about the appearance of the light. I really like the design of the Scorpion especially the knurling on the body and the regular head. Wish they could have the same knurling (minimum) on the turbo head. Right now the turbo head just seems a bit too plain, and do not match the style of the body.
On the negative side, I noticed on the regular head, there is a black metal ring in-between the glass o-ring and the SS bezel, on my sample there are 4 dents with hard-anodized surface being chipped-off. I can see it without taking off the SS bezel, it looks like it was cause by some kind of tool they use to assemble the SS bezel. The 4 dents are in pairs, meaning there are two dents on each side of the metal ring at exactly 180 degree opposite each other, and very close to the knobs of the SS bezel (not sure that is the right term). I am not sure if this is normal for the Scorpion regular head, if it is then I won't go through all the trouble ex-changing it.
I also got a free Thrunite Ti AAA in champaign color, that came with the Scorpion. The sad part is they do not have in stock the 0.4lm version, so instead I got the 3lm version. When comparing it to my Klarus Mi X6, the 3lm low seems a lot brighter than my Kalrus's low, and the high on the Ti is almost equal to the 85lm high on Klarus. This may be due to the more throwy focus beam of the XP-E on Ti, since the hotspot of the Ti are obviously smaller and brighter than the one from Klarus. The tint of Ti also looks more greenish compare to the creamy white on Klarus.
As a close-up working light I think Klarus creamy white floody beam are better suited compare to the Ti, but I really like the UI of Ti, so simple yet practical. I wish Thrunite Ti will get an upgrade later with a neutral/warm XP-G emmiter with more flood, and that would be a perfect keychain light for me.
