alfreddajero
Re: NiteCore EZ AA Review: RUNTIMES, BEAMSHOTS, PICS & more!
Once again another great review.
And gosh darnit, so do ours!Great minds think alike.
That's an excellent use for the watchpocket. Too bad I already carry a USB drive there, otherwise I could cram yet another light onto my person!As always selfbuilt, great job!! Can't wait to get mine. It should fit nicely in my jeans watchpocket when I don't want to carry my Ra Clicky.
You can put a light in there too; I've got my fingernail clippers, car keys and Titan in mine!That's an excellent use for the watchpocket. Too bad I already carry a USB drive there, otherwise I could cram yet another light onto my person!
Not likely ... along with the obvious tint differences, I would expect just slightly lower output. Everything else should be the same.Will you be doing an add-on to this great review when the Q3 5B version lands?
Yes, it would fit pretty well in there - just the tip of the light would show.It should fit nicely in my jeans watchpocket when I don't want to carry my Ra Clicky.
Looking at the EZAA first stage output and comparing it to the Lumapower X2, they are pretty close at 3 and 3.1 respective. Lumapower rates the X2 lowest output as 4 lumens which seems pretty accurate. ... The Fenix L1D is rated at 9 lumens low and has a value of 11 which is "pretty" close in relation. I think the LD1 was lowered by customer request but the literature did not change (not sure).
Well, I've never measured the runtime on Lo on my L1D on Eneloop, so I don't know how it compares. EZ AA Lo mode alkaline runtime will likely be done by tomorrow (or thursday at the outside) - that should tell us more, since I have data for a number of lights on alkaline at low levels.At less than 1/3 of the output the L1D has, it should at least be able to go 24 hours on one eneloop.
i wonder if anyone will be able to reduce the amt of turns from low to high.. i'm for sure gg to see if i can do anything to save some turns.
and btw, i bought this light in full faith that 4-7s will come out with a clip for it sooner or later... => a light with a clip is ALOT more practical IMO.
but thats how i use it..
I'm thinking the same thing. What's the point of making a new super small AA light to get more capacity than AAA lights if you're going to make it half the efficiency of the competition? I don't know how they manage make a constant current regulated circuit with less efficiency than the average pwm circuit. :thinking:"Low Mode: 15 lumens for up to 20 hours" that's what you can read in the specs.
I get this light in order to use mainly the low mode. But I can get more light from a Fenix E01.
Lets see...
E01: 10 lumens x 10 hours = 100 (if I remenber correctly, can't find a runtime right now)
EZ AA: 6? lumens x 16,3 hours = 97,8
and the EZ uses an AA that have 2,5 times more energy than an AAA.
I'm thinking in cancel my order.
"Low Mode: 15 lumens for up to 20 hours.............
Intermittent usage? What does that mean? I think they just changed it to 15 hours and forgot to change it the other place or something.i think 20 hrs is intermittent usage.
Intermittent usage? "5 years on the lowest setting (if you use it 2 minutes a week)" :laughing:
With intermitten usage any light will last for anything from a day to months. You can't measure runtime like that. If you mean intermitten as in using it now and then and combining the total usage, the runtime would still be the sames as if you used it 16 hours straight.I know it is unfair to test a runtime with intermitten usage, but I dont think anyone needs 16 straight hours of light. That is using the flashlight from the moment you wake up until you sleep. A true flashaholic.
