same reflector (kl6) but XP-e2 or XM-l2 what will be the best throw?
el_Pablo
South Korea / Switzerland
Hi guys,
I'm considering to mod a SF kl6 head, but I don't know if the large and deep reflector will work better with XP-e2 or XM-l2?
1.5 A for both options for the LED.
I have always understood that the XP-e/2 has a lower efficiency at the same current, but the smaller die matches the focal point of the reflector better.
Also, is there more lumens/surface(die) on it?
On the other and the XM-l2 is more efficient, but has a larger die, so less light is directly on the focal point
Is the lumens/surface not as high as XP-e2?
In conclusion, which one will throw better on this kind of reflector?
Thanks:candle:
Pablo
Epsilon
Netherlands
XP-E2 for sure. But, that is out of spec, you could better got with the XP-G2.
The efficiency of the XM-L might be higher, but the brightness of the die is a lot less.
