Illum
I'm curious why you epoxied the end cap to the bracket and the LED to the end cap instead of tapping screw holes in the bracket and using a pair of screws to hold the whole assembly together.
Granted, epoxy is a little more weatherproof than heatsink grease but I suspect it would be preferred if the ambient temps drop very low in winter, a large rapid thermal expansion of the end cap might be hard on the epoxy unless you use a type that remains flexible.
too bad the inside of the brass cap isn't flat, at all...the LED was seesawing around rather than staying still. My tap and die set was borrowed but never returned so I don't have tapping capabilities. As far as thermal expansion is concerned, if the LEDs are left on 24/7, chances are the temperature will be constant most of the year, but yeah that's something to think about
You mentioned having a drill press... you might get the holes started easier without skipping if the cap were put in a vise.
it was in a vice, it wasn't the cap rolling around, its the drill bit being pushed away as I lowered the chuck. the shop was designed as a wood working shop, I have plenty of drill bits but none designed for metal. :candle:
It's hard to tell but it looks like the edges of the star are resting upon the corner of the end cap where it starts to curve upwards, I wonder if the LED would sit lower, more flush with the cap if the edge all the way around the back of the star was ground or filed down a little bit. Then again, the picture might just be an optical illusion.
Good observation, the star is being held up by the sides as well as by the "hill" in the center of the cap. I used epoxy to fill the gap between the corner and the center.
drilling would require at least two screws for it to sit flush and if I was able to tap it, I don't have screws that I could guarantee won't short a couple pads together through the copper material its standing on.
The orange glow is a nice effect, but outdoors I doubt it will be long till the copper oxidizes and that glow is gone.
yeah, but until then its icing on the cake. :twothumbs
Its an unintended effect, from the looks of it I might actually do away with the copper cap and use hot glue instead over wire contacts:candle:
