Illum
Since dad is planning sometime next year to modify the gutters, I designed everything to fit together with breakouts as well as mounting them to the beams the way one would hang a picture. All I need is a Philips head and I can take apart everything and put them in rudimentary piles
Continued from yesterday
the last of the soldering
As mentioned yesterday, I was pondering the use of cellophane wrap.
Its remarkable ability to cling to the aluminum and acting as one single layer of plastic when overlapped had me optimistic...until
failure!
The LED still worked, but that made me change my mind about using it as a moisture barrier, and I went with the cheapest and readily available supply in my inventory room: tape
I used boxing tape to create a weather guard awhile allowing some air convection to access the LED. To prevent the tape from yanking the dome off, here's what I did
cut a 1" thick piece of tape and lay it sticky side up
Cut a ~3" thick piece of tape and adhere it with the 1" at the middle
Place the "assembly" over the LED, and only allow the sticky parts to contact aluminum
the heatsink design will not reach the temperature sufficient to melt the tape into a sticky mess, if it does, at minimum none of it will touch the LED
For the sheared dome LED, I decided to tape it down and seal it:shrug:
More pics will continue on the next post, for now my computer is still resizing them
failure!
