Another super fresh newbie here. Haven't slept for the past week discovering all the Ready-Made offerings and Blue-Label standard/hopped up possibilities.
I do have a question -- I noticed on a Custom offering mention of heat and the use of common sense when the light was on high mode. I would default to the same common sense caution if there seemed to be too much heat building at any time. Either from a mass produced or custom light. In anyone's experience is this something to be more concerned about with the Blue-Label pieces?
Thanks
Thanks
On the Alpha's the switch is recessed so it won't / shouldn't turn on accidentally. And it would need to get really hot to damage it.
I bought a Ready-Made. Availability rather than money was the reason. I was visiting friends and family in the states and the Alphas were not available at that time. I am very happy with my Ready-Made - the electronics, MCE emitter and Ledil boom are the same. It even has the primary seal ring. There are 3 differences: the Ready-Made driver mount is nickel plated aluminum rather than copper, the threads are Class II rather than Class III and the o-ring material (and color) is different. Of course the surface finish is different, too. I like the texture (the little grooves) on the Ready-Made. I am very happy with the Ready-Made. If you can wait, go for the Alpha.
The MCE with the Ledil boom is magical and I highly recommend this set up. Beautiful tint and perfect beam. The emitter is not over-driven, but it will get hot on high. I have a toy - a copper pocket rocket that is over-driven and it gets hot fast. The Prometheus lights are not like this toy.
Also, it is a pleasure dealing with Jason. He answers questions and helps you get the light that is best for your needs.
