oneinthaair
- Joined
- Jan 7, 2015
- Messages
- 503
So when will the process of the greatness begin?
I've waited a long time for a Mac style 18650!
-AL body
-Frosted optic
-H17F driver
-about clip, do you offer McGizmo style or Mac's?
Updated.
Neither, Don declined to supply clips and Mac's were made for him.
I can offer Okluma clips however since Jeff has agreed to supply some.
Gunga's is on the lathe now, your's and Mick's should be on the lathe next week.
There are two slots available now due to some changes.
Updated.
-AL body
-Frosted optic
-H17F driver
In that case, would it be possible for me to get a second in copper?
(If yes: H17F, Narrow, Clip).
Sheet updated, rock you have the last slot.
Reason I ask about the XP-Ls is I am starting to order parts for future orders and need to know what to order.
It is a step above the Icarus in features as it has FET channels as well, however this host can't use them due to the McClicky, so 3.04 amps is max. The Icarus also has a copper contact, but otherwise they are basically the same except the Icarus is twice the price.
The benefits of an H17F over the Qlite is the full user programmability, bump protection, and the temperature sensor which regulates current to keep the driver below a certain set temperature (60C by default). Also, the moonlight mode can be made lower than a Qlite moonlight mode.
A note on reservations, I am capping them at 40 as I am primarily able to work on them this summer, and as such I want to make sure I get them done. Should I get them done prior to classes resuming in the fall, I may open a few slots back up.
Updated mine to H17F & included a clip.
If another spot opens up I'd like one in Brass as well.
I have to comment on the way you've set this up - the on-line spreadsheet with the options (presume the bolded customer name is the current build / machining) is excellent. Adds alot to the communication!
