yuandrew
I was toying around with the idea of modifying/rigging an old "window shaker"* so I could control it using an external thermostat such as the NEST or Honeywell VisionPro WiFi but then I came across the GE Aros.--
http://www.quirky.com/shop/752
http://www.homedepot.com/p/Quirky-A...U-Window-Air-Conditioner-PAROS-WH01/205064945
Developed under a joint partnership with New York Based Quirky and GE Appliances, the Aros is a window A/C unit with Wi-Fi connectivity and could be controlled via a smartphone app. It pretty much seems to do for window shakers what the NEST thermostat does for central air.
I searched around some more and found two other A/Cs with similar features. One other window unit is the Friedrich Kühl series which could be equipped with the optional Friedrichlink WiFi module (not available yet though) for smartphone connectivity and control.
http://friedrich.com/products/residential/window/kuhl
http://friedrich.com/friedrichlink/
The other one I found is the Haier Aero (known as the Haier Tianzun in Asia) which appears to be a portable/self-contained unit (the type which vents the condenser through a hose leading out a window) that has Apple MFi connectivity for use with iOS devices and has some design elements from the Dyson "Blade-less" fan. It was announced this January at CES but doesn't appear to be sold in the US yet.
http://www.cnet.com/news/haiers-new-air-conditioner-is-the-first-apple-certified-home-appliance/
* "Window Shaker" = a term used to describe a window A/C unit which vibrates and rattles the window frame it is installed through
-- We have (or should I say had) central air but it somehow developed a mysterious slow leak a few years back and all the Freon is now gone and my parents don't want to repair or replace it; dad thinks I should just get use to the heat and mom thinks it would be more energy efficient to get some window or portable units and cool just the rooms we are in vs the whole house.
