The SureFire/Oveready tailcaps are not ideal for Solarforce L2P but can work. What qualities are you looking for in a body? You said smoothie, but are you looking to have a lighter body? Because the Oveready 6Z is quite light. I have one on order and expect it before Friday. I also ordered another Triad tailcap because they are fantastic for comfortable, precise control of dropins designed for throw. So if you are going to spring for the (expensive) Triad, you might as well keep your build balanced in quality and get a shaved Oveready body, my opinion. That is, if there are any available.
I mean, if you have a tendency to lose lights then maybe go the budget route. Otherwise, just enjoy the fine quality of the real thing. Their customer service is stellar, I might add. They have put up with a lot from me, and the satisfaction is really top notch.
Otherwise, maybe someone here can steer you towards something cheaper. My Overeadys will last for life. And experimenting, I have easily replaced the McClicky switches in an Oveready tailcap. The Zero Res 'switches' are essentially eternal. If you did get a Zero Res, check out the polishing on the inside face; really high quality. In this case, you get what you pay for.
Sent from my iPad using Candlepowerforums
