flashflood
- Joined
- Mar 9, 2011
- Messages
- 608
If we can agree on some common test currents for certain size cells, I'll gladly do additional tests. I just don't want to do a bazillion more tests as this little endeavor took the better part of a week+. It's the recharging of the cells that I hate...
-DF
For the smaller cells (18650 and below) I would suggest 1.4A and 2.8A because they are such common drive currents. Moreover, adding those two curves should be sufficient to allow interpolation. For the larger cells, I'd suggest two currents between the min and max -- ideally logarithmically spaced, i.e. the ratio between currents should be the cube root of max/min. That will give you four nicely spread curves, two of which you have already generated.
