Re: Replacing the emitter?
This all makes me think that it would be great if the Spark's were manufactured in such a way you could upgrade or swap out the drivers and emitters easily. I've accidently unscrewed the end cap with the driver in it a couple of times so it shouldn't be all that hard. Would be neat if you could have some different end caps with different drivers that you could change in and out as required. And as Spark already has the screw-in bezel, perhaps they could make a similar arrangement where the emitter of your choice screws in with the bezel. While it may burn a hole in their forehead, some might want the ability to swap the driver and run an XM-L2 at 2.8A for example.
Otherwise if I want a 3000K high CRI light I'd probably go the easy route and just get a cheap DIY host, driver, and emitter on a star, and assemble them from scratch.
