Spy 005 v.1 discharge while off?
Lunal_Tic
The Wilds of Tokyo
Spy 005 v.1/v.2 discharge while off?
In anticipation of receiving my Spy 005 v.2 I took out my v.1 model which I hadn't used in several months and the batteries were dead. One was 2.53V and the other -.85V both read as dead on a ZTS. Has anyone noticed a self discharge on these when parked for a while and not used?
TIA,
-LT
TranquillityBase
Yep, mine too.
I think this is one of this issues that will be resolved, with the electronics upgrade offered, for older model SPY lights.
Archangel
PA, USA
I've never noticed this on mine, but mine goes through batteries fast enough that i'm not sure i would. This is definitely something i'll follow though since i'm still trying to decide if i want to upgrade.
Kiessling
Old World
Just checked mine ... dead, too.
Interesting. I thought the board would have a hardware "off" position
bernie
fasteddie
Austin, TX
The batteries in my two classics seemed fine after long rests. #89 has never been taken out of the box... still has the foam wrapped around it... and it lit up like it had brand new batteries. But on the ZTS it showed 60% one one and dead on the other. Needless to say, I've removed the batteries.
karlthev
Pennsylvania
Hey, watcha doin' just lettin' these pretties sit in in a drawer??? :thinking:Shame on ya!! :shakehead Just kidding of course. I EDC my natural 005 so it gets used all of the time. I removed the batteries from my black 005 and can't tell you what may or may not have happened had I not.
Karl
fasteddie
Austin, TX
Karl
Karl, I have lots of lights that just sit around... all the way back to ARC LS colored hi-domes. sigh. I've been reluctant to remove the batteries from the spys because of what I read about knobs becoming disengaged if you turn without a battery in place. Also, since polarity isnt marked on the light (as no good custom would ever do) I didnt want to mix it up. Today when I took the batteries out, I put a note in the box about the polarity. I have carried my ti v2 spy since the day I got it. I carry the cree ti and am saving the seoul ti as a back up. God are they bright compared to v1!!!! I've also installed trit. Maybe the best light I've ever owned. If I could clip it to the bill of my cap, it would be perfect. Can't wait to get my v1 lights upgraded.
TranquillityBase
My light was sitting for a very long time, probably close to a year, not sure...
I can't see this as a problem for light that is used on a regular basis, but I'll store my classic 005 empty from now on.
Lunal_Tic
The Wilds of Tokyo
There are markings on the circuit board if you look carefully. I went ahead and used a silver Sharpie to mark inside the tailcap too though just in case.
-LT
Data
PA, USA
Polarity is marked on the PCB of every SPY. There is a plus and minus mark right by the terminal.
The SPY circuit boards do use a small amount of power when the light is off. If your light is a shelf queen, I recommend putting a small piece of paper over the end of one of the batteries and then put the battery cap back on. Or just take out the batteries.
It is always a good idea to put a little lube on the battery cap o-ring from time to time.
Cheers
Dave
Lunal_Tic
The Wilds of Tokyo
Re: Spy 005 v.1/v.2 discharge while off?
I'm giving this a bump to see if anyone has had this auto discharge problem with their v. 2 Spy005. I haven't had mine go completely dead because it's in my EDC rotation of lights but the batteries do seem to peter out more quickly than would be dictated by use.
Was the power leak fixed with the v.2 boards or were they essentially the same as the v.1 boards in this regard?
-LT
Data
PA, USA
-LT
What are you calling a V.2 ? Are you referring to the STFu?
Data
PA, USA
Yes, those 005's had the STFu converter board. I suspect yours has the wrong version of code in it (a version that does not shut down all the way). We found some of them already but I did think we got them all. Just send it back to me and I will upgrade it to the latest code. It is pulling 300ua in the off state and should pull 5ua.
Send me an email an we can work out the details.
Cheers
Dave
Lunal_Tic
The Wilds of Tokyo
Cheers
Dave
Thanks for the heads-up. Email inbound.
-LT
